Is there a right up anywhere for replacing these things
door pins and bushings
Re: door pins and bushings
I just removed the driver door on my dump truck at work and I had to put the spring in a vice and clamp it way down, then I used 2 HEAVY duty zip ties to hold it compressed and when I put it in I had to close the door a little way so the spring wouldn't fly out and kill someone and I just cut the ties.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
