noticed theres no coolant running from the radiator to the hose that runs to the thermostat. I tried bleeding the air out through the bleeder screw but no coolant came out. What could be wrong? thermostat?
It's got to be either not enough coolant or a thermostat that's stuck closed. Do you get heat? If you have heat there is at least enough coolant to circulate through the engine.
