problem #2 - FirebirdV6.com/CamaroV6.com Message Board
problem #2
  • problem #2
    noticed theres no coolant running from the radiator to the hose that runs to the thermostat. I tried bleeding the air out through the bleeder screw but no coolant came out. What could be wrong? thermostat?
    Re: problem #2
    maybe not enough coolant in your system. that would be my guess if your only getting air out. or a major furball
    WAWA-A-HOLIC
      Re: problem #2
      will check it out, radiator is full but havent checked the are where you actually fill it
        Re: problem #2
        Actually fill it? Don't you just fill the radiator? That other tank is the overflow tank.
          Re: problem #2
          i know but i check both for accuracy....dont get why nothing would be running to the thermostat though, dumbfounded..
            Re: problem #2
            It's got to be either not enough coolant or a thermostat that's stuck closed. Do you get heat? If you have heat there is at least enough coolant to circulate through the engine.
