Car is shaking - FirebirdV6.com/CamaroV6.com Message Board
Car is shaking
  • Car is shaking
    My car all of a sudden has started shaking while driving. The shifter was shaking around alot so I figured it was the tranny mount. The mount was torn so I changed it. It still shaking.
    It does seem to change frequency with speed. All of the wheels are on tight, the engine runs fine, I don't feel it in the steering wheel, and I don't hear any odd noises.
    Its definitely in the drivetrain because the tranny is shaking the shifter around.
    Any ideas of what could possibly cause this. Would a bad motor mount or u-joint cause this? I won't be able to get back under the car until next week to check things and I want to make sure its safe to drive.
    I'd hate to drop a drive shaft or lose a wheel on the highway. If anyone has had this problem or can give me any insight I'd appreciate it. Thanks.
    Re: Car is shaking
    I was going to say Vaccum leak , but if the cars running fine and you have a new trans mount, I would say engine mount.
      Re: Car is shaking
      check u joints or maybe a bad drive shaft
        Re: Car is shaking
        Sometimes improper balance on the wheels can do that. But you mentioned mounts. Check all mounts engine and tranny and more sure they are tight.
          Re: Car is shaking
          does it shake during idle or parked? If so, you can get jack the car up to see what is moving/hitting.
          1998 Chevy Camaro 3.8
          1997 Chevy Camaro Z28 - SOLD 7-23-2011
          1996 Chevy Camaro Z28
          2001 Pontiac Firebird Formula
            Re: Car is shaking
            I'm starting to think its just a wheel out of balance. Its odd that It started all of a sudden. It was fine until I pulled into a gas station to fill up and then after I pull out the shaking started. I think I must of lost a wheel weight. Not sure if losing a wheel weight would cause this much shaking though?
            My best guess is a rear wheel since I don't feel it in the steering but really feel it coming from the tranny. I have an old bubble balancer in the garage. I've never used it and not sure how accurate they are but I'll give it a shot.
              Re: Car is shaking
              Sounds like wheel weights, I had a similar experience. driving on the highway all of a sudden the car started shaking like crazy. This was a week after the entire wheel flew off of my rx7 it felt like that so I freaked out and pulled off to the shoulder to check as much as I could. Some how 3 of the 4 wheel weights were missing. New tires next day + new weights = fixed.
                Re: Car is shaking
                Finally got under the car and looked around. It turns out the belt in my left rear tire broke. Nearly 1/4 of the tire on the inside half had collapsed into a big flat spot. I didn't see it earlier because the outside of the tire looks normal.
                Odd considering it happened suddenly, I hadn't hit anything it and the tires are only 2 years old with good tread.
                  Re: Car is shaking
                  what brand?
                    Re: Car is shaking
                    Its a Kumho Ecsta AST.
                      Re: Car is shaking
                      I'm surpirsed their normally a good tire.
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
