coil pack bolts - FirebirdV6.com/CamaroV6.com Message Board
coil pack bolts
  • coil pack bolts
    I broke 3 of mine, so 2 questions.
    A) whats the easiest way of getting the other half out of the bracket? Just drill it?
    Can I use a nut/bolt combo to re-secure it?
    B) does anyone know the size of these bolts?
    I've driven like this for awhile now, one bolt holding down each pack, but since I changed swapped in some new ones last week I've been getting intermittent misfires as of today...when I check the rear coil pack it's sloppy, so I'm guessing thats the issue...its just pulling itself up with vibration and intermittently firing.
    Re: coil pack bolts
    Can you get a new bracket all together? Might be an easy solution if you could find one on the cheap side, bolts included
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      Re: coil pack bolts
      not before my road trip tommorrow lol...
        Re: coil pack bolts
        are the coils grounded by the bolts? or just those prongs on the ICM?
          Re: coil pack bolts
          thats a good question. i dont think they are grounded by those bolts but I could be wrong. Maybe just some zip ties for your trip? lol
          Dave:
            Re: coil pack bolts
            problem is I'm not sure if the hole goes right through the bracket right now. If it does, Im thinking of just getting a nut/bolt and attaching the coils that way.
            and if it's not, Im thinking of just drilling right through the bracket...I think it should be ok, I can't forsee an issue, Im just asking just to be sure though. I mean you would think its just a regular bracket right? ....and even if I did drill all the way through the holes if I use a nut/bolt and the packs were grounded through the bolts...technically they should still be grounded no?
              Re: coil pack bolts
              Yes they are grounded, I noticed mine were off when my stereo noise got bad. Now they are wedge in there tight so they have a ground to them, its alot better.
                Re: coil pack bolts
                I wonder if this was causing my dip in volts everytime I come to a stop...
                  Re: coil pack bolts
                  Thats the big cam your running.LOL Whats your idle set at? I have mine at 900 RPMS.
                    Re: coil pack bolts
                    you know oddly enough my cam doesnt set the P0300 code which I still have enabled...
                    I have my warm idle set to 860, and extreme cold idles set to 1200rpm
                      Re: coil pack bolts
                      Thats good then, I would of thought it lobed like crazy.LOL
                        Re: coil pack bolts
                        oh it does...about twice that of the ARH cam...the hood shakes lol...I actually have to loctite all my bolts because it shakes everything loose...Ive lost both coil pack bracket bolts before, tranny dipstick bolt 3 times before I put blue on it, my powersteering pump bolt lol...its brutal...
                          Re: coil pack bolts
                          got a junkyard around? Just grab another ICM and everything off a grand pri or bonne or something.
