Replaced Rear O2 sensor with O2 sim for P0420 Code. - FirebirdV6.com/CamaroV6.com Message Board
  • Replaced Rear O2 sensor with O2 sim for P0420 Code.
    I was just wondering, how long will it take for my SES to go out? should it happen instantly or will it take awhile?
    Re: Replaced Rear O2 sensor with O2 sim for P0420 Code.
    You have to reset the light. Take it to a parts store or somewhere they can reset it, because it has a pending code in the PCM still.
      There's a code reader scanner you can buy at any parts store for OBDII and it does have an erase selection on it.
      OR you can simply unplug your battery for a couple of minutes and plug back up again. I haven't done this with my 4th gen bird but it works with my other cars.
        What docta said, they usually have ones you can use in the store, reset it real quick for you.
        Team NoVa
          I went to the autostore and had it reset by O-Reilly's...yay.
          Im hoping I never see this code again. Im ganna push for an Emissions test tomorrow after work.
            I put a sim in mine about 5 months ago now, and no problems since.
              Still trying to find oil leak
              3 days ago
              Getting some work done on my truck
