New Firebird owner Q - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    So I dint know if this is the placebo effect going on here.,. But I have noticed that after a while of driving the car it gets worse at shifting into second. How can I actually troubleshoot this issue? And is it the TCC or TC solenoid? (Maybe its the same thing?) Also, how hard is it to do this procedure? Where can I purchase the needed item?
    Sent from my Samsung Fascinate using Tapatalk.
    • #17
      Re: New Firebird owner Q
      Before I sold my car I bought a shiftkit and a cheapo tcc solenoid from ebay. around 300$ total give or take, after a shop installed it all for me.
      If you just wanna get the solenoid there only 20$ or so on ebay.
      Though shiftkits usaully fix the issue alone and will make it funner to drive too. Depends what you wanna do.
      I did both so I wouldnt have to worry about it.
      -Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
      • #18
        Interesting. What exactly is it? Can you.give me some links please??
        Thank you!!
        • #19
          The shiftkit I used:
          http://www.ebay.com/itm/TransGo-Shif...item4cfac20d9d
          and a tcc solenoid:
          http://www.ebay.com/itm/4L60E-4T40E-...item35b3d6b855
          that and the shop charged me 200$ to install all of it so about 300$ if you take it to the right shop and do some shopping.
          • #20
            Be advised that this 3.8 is very vulnerable to self distruction if the car overheats.
            Be very careful.
            • #21
              Be very careful.
              Any engine can be subject to problems after overheating. I have yet to see evidence of the 3.8 being especially vulnerable to destruction after experiencing higher than normal operating temps. Iron block (and iron heads in this case) tend to be more forgiving.
              '99 Camaro
              '04 Saab 9-3 Aero
              '90 Audi Coupe Quattro
              • #22
                I never said my car was overheated either. o.o
                • #23
                  Didn't even post about this. Ha. But I think that's what I am going to do. But probably install it myself(with my fathers help).
                  • #24
                    In my case it was the actual valve that needed to be replaced. What it is is a cylinder in a bore, with a spring. The bore becomes worn, causing fluid to leak past the cylinder. To fix it they drill the bore, put a sleeve in it and then put a new cylinder in it. That's to fix the actual valve itself.
                    http://www.hotrodders.com/forum/has-...it-196802.html
                    Team NoVa
                    • #25
                      I see. So how do I determine which it is? Would I need to remove the Tranny (autocorrect totally changed that to granny haha) and crack it open and check the tolerance?
                      Thanks!
                      • #26
                        Flaming chicken probably had something similar to me. i have a little leak which is more then likely my tcc valve and its given me a hardshift as well. pretty sure the transmission is on its way down, but im just going to have it rebuilt with a shift kit and torque converter and such
                        Wait, Is that a V6 or V8?
                        • #27
                          Interesting. I am eventually going to get a new TC and hardened output shaft etc but need to get finances straight first.
                          • #28
                            Mine went for about a year after I noticed the hard shifting before I had legit problems. I even dropped the trans pan and changed the filter to check to see if that would remedy the problem prior to figuring it out (or having it figured out for me.) At that time the little magnet in the pan didn't have that much material on it, and the fluid itself didnt look too bad. I would say as long as you aren't driving long distances and letting it get to the point that it starts to slip, you should be fine for a couple months.
                            As far as checking the tolerances, I am not sure. I just have a long history with this problem so I learned a ton about it.
                            Team NoVa
                            • #29
                              So for $20 I might as well just change the solenoid while I do the kit, yes?
                              • #30
                                I would. They're very problematic... I'd get a shiftkit too if you can spare the coin. That solves the p1870 code for good.
