main seal - FirebirdV6.com/CamaroV6.com Message Board
main seal
  • main seal
    so i found out today my rear main seal is leaking. unfortunately the shop told me itd be around 500-600 dollars. i was wondering since they're gonna have it torn apart what else should i have replaced since they have it torn apart?
    Re: main seal
    I'd be interested in ideas as well, my rear main is leaking pretty bad right onto my new y-pipe :(
      Re: main seal
      Mine is leaking too. The cost there is dropping the transmission to reach the seal. There really isnt too much else besides that seal in there. I suppose you could have them check out your transmission mounts. I've got nothing other than that.
        Re: main seal
        The seal itself is cheap, it's just the labour involved in dropping the tranny (as said above).
        If the leak is slow it's usually cheaper to just top the oil up when ever it needs it.
        In America's Hat!
        1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
        2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
          Re: main seal
          depends on if you have an auto or manual
            Re: main seal
            i have a manual. i was thinking should i just get my clutch and flywheel replaced?
              Re: main seal
              you dont need a new flywheel, but if you have the money, you might as well do a clutch, slave cylinder, and pilot bushing, unless your car has low miles
                Re: main seal
                How much would that cost? I've got 125k on all those stock pieces..
