so my car was misfiring in cylinder 6. Swapped plugs out nothing, so i took out the wire going to it and saw it was burned through exposing and making contact with my headers. So i changed the wires out and zip tied the #6 one it so it would make contact. Started her up and drove it a bit and ran fine again. Went to start it a little later and it had the misfire again in the same cylinder. I know i should have changed the plug out but thought it was fine because it ran fine in the beginning. i guess my question is if the problem is most likely the wire again or the plug thats most likely fouled. i guess its a stupid question to ask but im confused because it was fine at the beginning then the problem came back
misfire question
Originally posted by firebird19_99 View Postso my car was misfiring in cylinder 6. Swapped plugs out nothing, so i took out the wire going to it and saw it was burned through exposing and making contact with my headers. So i changed the wires out and zip tied the #6 one it so it would make contact. Started her up and drove it a bit and ran fine again. Went to start it a little later and it had the misfire again in the same cylinder. I know i should have changed the plug out but thought it was fine because it ran fine in the beginning. i guess my question is if the problem is most likely the wire again or the plug thats most likely fouled. i guess its a stupid question to ask but im confused because it was fine at the beginning then the problem came back
And it was fixed until later. But then you say that you should have cchanged the plug out but didn't think you needed to... so did you take out the new one and put back in the old one or what?
What I would do is replace the plug if you haven't already and also the wire if it is not. And then if that doesn't fix it, check the ignition coils.
Sent from my Samsung Fascinate using Tapatalk.
