Ls1 cost? - FirebirdV6.com/CamaroV6.com Message Board
Ls1 cost?
  • Ls1 cost?
    How much do LS1s cost these days? From wrecked cars or anything of that nature?
    Sent from my Samsung Fascinate using Tapatalk.
    Re: Ls1 cost?
    www.car-part.com
    www.craigslist.org
    www.ebaymotors.com
    http://ls1tech.com/forums/marketplace/parts/search/
    I think you get the idea.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      Re: Ls1 cost?
      You will be better off buying a whole running car and selling your V6.
        Re: Ls1 cost?
        Or give me $3000, and I'll give you the complete drivetrain out of my car. Runs mid 11's.
          Re: Ls1 cost?
          Buy a high mileage Z28. Its cheaper than swapping that engine into your car. LS1's aren't cheap. If you want cheap than go LT1.
            I think you guys are meaning like high end stuff. I'm just looking for the basic engine. No mods or anything. I would rebuild and do internals and stuff before the swap. Looking for "junkyard prices" for lack of a better term.
              Re: Ls1 cost?
              You can get a running/driving LS1 F-body for under 4k if you look hard enough. I just saw one go locally for around $2800 for a 2000 with 190k miles.
                Re: Ls1 cost?
                Its not uncommon to find a 5.3 or 6.0 out of a truck for a few hundred bucks.
                  Okay. What is that labeled as? I.E. LS1, LT1, etc.
                    Re: Ls1 cost?
                    Trucks still have LSX engines.... be it LS1, LS2- LS9 are all still the basic engine with different components.... Be it 5.2L or 6.2L...
                    In America's Hat!
                    1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
                    2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
                      Re: Ls1 cost?
                      Well just off the top of my head. (jk)
                      GM LS engine (Gen. III small block)
                      Type RPO Name Displacement
                      V8 LR4 4800 4,807 cc (4.807 L; 293.3 cu in)[11]
                      L33 5300 5,328 cc (5.328 L; 325.1 cu in)[12]
                      LM7 5300 5,328 cc (5.328 L; 325.1 cu in)[13]
                      LM4 5300 5,328 cc (5.328 L; 325.1 cu in)
                      L59 5300 5,328 cc (5.328 L; 325.1 cu in)[13]
                      LQ4 6000 5,964 cc (5.964 L; 363.9 cu in)[14]
                      LQ9 HO 6000 5,964 cc (5.964 L; 363.9 cu in)[15]
                      GM LS engine (Gen. IV small-block)
                      V8 LY2 4800 4,807 cc (4.807 L; 293.3 cu in)[16]
                      LH6 5300 5,328 cc (5.328 L; 325.1 cu in)
                      LY5 5300 5,328 cc (5.328 L; 325.1 cu in)
                      LMG 5300 5,328 cc (5.328 L; 325.1 cu in)[17]
                      LC9 5300 5,328 cc (5.328 L; 325.1 cu in)
                      LH8 5300 5,328 cc (5.328 L; 325.1 cu in)
                      L76 6000 5,967 cc (5.967 L; 364.1 cu in)[18]
                      LY6 6000 5,967 cc (5.967 L; 364.1 cu in)[19]
                      LFA 6000 5,967 cc (5.967 L; 364.1 cu in)
                      L92 6200 6,162 cc (6.162 L; 376.0 cu in)[2
                        So I take it the "x" in LSX is a variable replaceable with 1, 6, 9, etc?
                          Re: Ls1 cost?
                          You are correct. LS engines are a whole family that that is based on a new design compared to the older smallblock style. http://en.wikipedia.org/wiki/GM_LS_engine
                          96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
                            Re: Ls1 cost?
                            Be careful when checking out a 5.3L as 4.8L blocks had 5.3L stamped/cast on them as well.
                            They(4.8L) had a shorter throw crank and flat top pistons.
                              Re: Ls1 cost?
                              Well good luck finding one of those in a junkyard. Maybe its just my local junkyard but I can tell you they will not only be gone within minutes of being there but at a higher price.
