This is a brand new driverside headlight motor...and the D.S. motor has ALWAYS been stripping geae its 3rd gear (and this is a NEW NON REMAN MOTOR) ..btw this is the first gear this motor has had and it IS the Aluminum Gear... but it stripped within 1 month of use. I already know about the water problem but the cover screws onto the housing. it doesnt require glue. The previous motor WAS glued on and failed roughly within the same time frame. Im at a loss for thoughts..why am I eating gears so rapidly on the driverside.
Keep stripping headight motor gears.
Re: Keep stripping headight motor gears.
The passenger one is fine? Only the driver side keeps stripping?
Do both headlights go up and down correctly?
Only reason I've ever stripped gears including the brass and/or metal ones is the play that some of the housings get when they break.
I had to get reman'd motors cause my housings were broke and would cause them to strip.
Kinda odd that only 1 side is doing it as well as a brand new one...?
Have you checked to see if the housing has play in the middle of it? Mine would move side to side cause the part that holds it together was messed up.-Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
do they both go up and down at the same time when they worked?
I installed brass ones early this year and 3 days ago I removed the DS motor because the glue that came with the brass gear kit sucks.
What I did was use a cement glue and I used 2 wires to clamped them just in case the glue fails to hold again. So far so good everything is fine.
IDK why yours are failing like that. Check the housing, see if the gear is spinning OK, and see that it's properly greased. I would recommend that you glue it and then clamp it down with wires or maybe with a real clamp.
Originally posted by firebird19_99 View Postsame thing happened to me found out it wasnt sealed right then i ordered re-manufactured ones with the metal gear and theyve worked fine for me.1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
Do these gears require any lithium grease or moly lube to enhance gear meshing?
Sounds like an ingredient missing to me.
Former '91 Firebird owner ;)Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
I think this is better.
www.rodneyd ckman.com/n113.html
Add the "i".
I used this on mine.
.Last edited by FirebirdGT; 11-18-2011, 06:23 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
