RPO code - service parts id - FirebirdV6.com/CamaroV6.com Message Board
  • RPO code - service parts id
    On my door jamb service parts id codes...
    One of them says L36. If I look up the L36 code, it says "427 cu. in. - 390 HP". For a V6? I think not...
    Does anyone know what this code actually means??
    Thanks.
    Re: RPO code - service parts id
    3800cc 3.8L 267 ci V6 200HP
      Thanks.
      You should become familiar with our databases.
      http://tech.firebirdv6.com/generalspecs.html#RPO_Codes
      Raven
        L36 was changed to the 3800 V6 (231 cid). It used to denote the big block in the 60's I believe.
        Stephen<br />1995 Pontiac Firebird<br />3800 Series II V6<br /><br />2000 Pontiac Firebird Formula
          Still trying to find oil leak
          2 days ago
          Getting some work done on my truck
