I cant smell coolant anywere but every 2 weeks I have to add coolant to the engine, probably about half a gallon. When car is idling, no visual leaks, no leaks anywere - no smell of coolant, just a slow disappearance of coolant... Intake Gasket failing?
Slow coolant leak + no smell...Intake Gasket Leak?
Re: Slow coolant leak + no smell...Intake Gasket Leak?
Might be the coolant elbow from the lower intake manifold. See if you can see steam coming from the ALT. thats how I found mine before.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostMight be the coolant elbow from the lower intake manifold. See if you can see steam coming from the ALT. thats how I found mine before.
Originally posted by ssms5411 View PostMight be the coolant elbow from the lower intake manifold. See if you can see steam coming from the ALT. thats how I found mine before.I solemnly swear I am up to no good.
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 days ago
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
