So my car is throwing codes : P0305 (misfire cylinder 5) P1362 and P136?? I just changed out the ICM also yest. Any ideas where to start with those last two codes?
Car throwing codes and misfiring
Re: Car throwing codes and misfiring
i would test the coils, plugs & wiresWait, Is that a V6 or V8?
Originally posted by ACiFiC View Posti would test the coils, plugs & wires08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Why did you change out the ICM - was that before the codes?96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
yes the icm replacement was before, the main reason why is because one of the coils looked bad (metal exposed) and the bolt holding it was rounded off so i ended up destroying the old icm getting it off so i replaced it along with the coil. If the coil was bad wouldnt it cause multiple misfires? but will check it all tomorrow finally get a chance to work on it. This misfire comes back every month just jumped cylinder. Even when i think ive fixed it its still there when i press the gas hard but runs fine if i drive normally. I dont get why
