Replaced the drivers mirror assembly after i mistakenly tore it off backing up. Got new housing with glass mirror but when I drive the glass shakes. Anyone have an idea of how to fix this? Thanks.
Jittering drivers outside mirror
Re: Jittering drivers outside mirror
the obvious answer is....very carefully.... well really.....
you are going to just pull on the glass preferably from both sides at the same time. the balls are sitting in plastic and are kind of anchored in, you'll see what i mean once you get it off... but before you take it off. you might want to just tilt the glass al the way to one side and see if you can see whats not connected you might be able to just push it back in.
