My front O2 sensors lasted 6 months before throwing the codes: P0133 / P0153
The codes set when the sensor's switching between rich and lean is too slow. To control the A/F ratio, and make the cat work, the PCM swings the A/F ratio back and forth rapidly from slightly rich to slightly lean continuously. The cat stores oxygen when the mixture is slightly lean, and uses the stored oxygen to oxidze unburned HC's and CO when the mixture is slightly rich.
Why did my Bosch's only last 6 months? I am shooting for straws cuzz I dont want to replace them and have them prematurely die again. The only thing is, is I MIGHT have a coolant leak in the intake gasket but even thats uncertain at this point.
