I turn on my car and the gauge is working just fine, got up to temp and everything. However, about 30 min later I look down and its reading 0, but about 10 min after that it started working again, so I'm confused. Another thing, when the gauge wasn't working it sounded like the fan was running constantly, and as soon as at started working again the fan stopped. Any ideas?
temp gauge not working
Re: temp gauge not working
On my 02 that was the default mode for a bad thermostat, my thermostat was stuck wide open so the car took too long to get up to normal operating temperature.
The computer doesn't get a correct temperature reading so it goes into safety mode by turning on both fans..
I would check your coolant temp harness to see if its shorting , other than that check the sensor to make sure its still good.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You should get .5 volts from the sensor when plugged in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If the motor doesn't heat up properly after a few running cycles, it will shut off the temp gauge and turn the fans on.
It's similar to limp mode in the FI system, when the computer senses a problem it goes into safe mode, in this case that's both fans on and no temp gauge.
The most common reason for a car taking too long to warm up is a thermostat that's stuck open, that's assuming some one hasn't wired the fans to run all the time or some thing like that.
sounds like a bad sensor or short to me too. Intermittant electrical problems are the worst. You have to diagnose them when they on the fritz or visually inspect the whole circuit (follow the wire and look for breaks, cracks, shorts etc). Connections could be corroded too, so disconnecting connectors and cleaning them up may help if the new sensor doesn't do it for you. I would *think* a wide open thermostat would just read cool. I've never seen a wide open thermostat jump from normal temperatures to 0 in my short lived shade tree mechanic experience. If it was stuck wide open, it would just take forever to warm up. That the fans are kicking on indicates to me that it is a sensor and not a guage problem.
The reason the fans kick on is because the computer is sensing a fault (like 0 volts or ground) and is kicking them on to be safe.
Originally posted by landj View Postsounds like a bad sensor or short to me too. Intermittant electrical problems are the worst. You have to diagnose them when they on the fritz or visually inspect the whole circuit (follow the wire and look for breaks, cracks, shorts etc). Connections could be corroded too, so disconnecting connectors and cleaning them up may help if the new sensor doesn't do it for you. I would *think* a wide open thermostat would just read cool. I've never seen a wide open thermostat jump from normal temperatures to 0 in my short lived shade tree mechanic experience. If it was stuck wide open, it would just take forever to warm up. That the fans are kicking on indicates to me that it is a sensor and not a guage problem.
Originally posted by rod knock View PostThe computer reads the temperature, if after a certain amount of time the temp isnt where it should be, it goes into a kind of safe mode, it turns the gauge off and turns both fans on.
