http://www.youtube.com/watch?v=cDByU...ature=youtu.be i have this little walk around on my camaro and this nasty engine noise idk what it is anyone know?
engine noise.
Re: engine noise.
Oh god where do I begin with what's wrong?
I'll just stick with the engine noise: It sounds high pitched like an accessory bearing (alternator? idler? etc.). Take off the belt, start it up without the belt (just breifly) to see if there is any noise still. If no noise then its an accesory. Shut it down. I'd recommend grabbing each pully and spinning it to see if there is a lot of resistance. You can also wiggle each pulley to see if any are loose. If you find an accessory that's out of wack, then you've got your culpret.
Now for the stickers, dirt, and music... well that will have to be another thread.Last edited by landj; 01-17-2012, 01:00 PM.
Re: engine noise.
Re: engine noise.
X2 on the stickers and dirt....
X2 on taking the belt off and spinning things by hand.
Sounds like it could be a water pump, but most likely something on the accessory belt.In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
Re: engine noise.
Originally posted by landj View PostNot hating. Just not a fan of stickers or dirty cars. so what happened when you took off the belt? racing crew? and my dad lives out west so nothing but dirt. and its the water pump.
Just took another look at your video. What's with the dryer duct? Is there hose clamps on there?
Re: engine noise.
Originally posted by redv6 View Posti lost my below and had to find something and its works like a champ way better than my stock :)
Originally posted by redv6 View Postyeah its the water pump
Re: engine noise.
Originally posted by landj View PostMake sure there's a good seal around it (hose clamp?), I'd hate for you to suck up sand, salt or dirt. nothing comes in it . it clamps its self .
Fun, I've just did mine for the second time when the chineese Duralast decided to fall apart after 18k. It's not bad, but I hope its easier to change for you than than it is on the 3.4. There should be some good write ups on this site to help you along.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
