Nasty Pics - FirebirdV6.com/CamaroV6.com Message Board
Nasty Pics
  • Nasty Pics
    Ok, so I've been having some problems with the car starting in the winter recently and today after I had to jump it, it had a real rough start and ALOT of white, very smelly smoke(not the typical smoke you'd see in the cold) came out and I let it run to charge the battery but now it's dead again.
    I took a look under the hood and popped open the radiator cap and as you can see from the picture, there's some crap on the cap and in the radiator, the fluid is brownish in color and the stick that goes in the overflow tank is crusty in the brownish, black crap. I might add, there appears to have no fluid in there.
    I opened the oil cap and on the oil cap there's a greenish, yellow substance all over the cap and inside the shaft that you pour the oil in. I also might at that the inside has some burnt orange all along the inside.
    My initial guess is a blown head gasket but I hope someone can confirm or deny from the description/pictures
    Re: Nasty Pics
    forgot the radiator cap picture.
      Re: Nasty Pics
      Sorry to see , mine might be blown too.
        Re: Nasty Pics
        You definately answered your own question.
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
