Alright guys so I am a bit confused. Typically with the walbro 255 36lb injectors I see around 50 psi at idle and usually 60 psi when the pedal is to the floor. The strange thing is my fuel pressure has dropped to 40-45 psi at idle and goes up to 50-55psi under boost. Strange thing it I have no surge, no misfires, no lean idle, or lean conidtions under boost. My wideband reads 14.7 with some deviation at idle, and 11.3-11.5 under full boost.
The other strange part of it is I have driven 143 miles and I have only burt around a quarter tank of gas (really a little less).
If you guys think that there is an issue or if its fine let me know.
