so i changed my oil the other day and got a good look under my car and saw that it has oil everywhere. oil pan tran pan. like everywere i got a new tran filter and gasket and im thinking some rear main seal stop leak crap should work. but is the oil pan hard to take off.? and does any one have this problem my car is an auto and from 10-35mph i punch it and right under something hits hard in the center console and it sounds like there is something loose under my car.
leaks
Re: leaks
Oil pan hard to remove? No - just need to jackup the engine! :rolleyes:
Dealer wants $800 to replace my leaking oil pan gasket.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Re: leaks
Great thing about Tub. K member you can change the oil pan without any problems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: leaks
Originally posted by ssms5411 View PostGreat thing about Tub. K member you can change the oil pan without any problems.
Raven
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
