My radiator recently started leaking in one little spot on the left hand tank (where it meets the core.) Should I take it to a radiator shop and have them fix it? Or should I just buy a new one? If I buy a new one, is there a difference between the V6 and V8 radiators? If so, would it be better to get the V8 radiator?
Thanks in advance.
BTW - My car is a 2001 M5 Camaro with the 3800.
I think the V8 is slightly larger, I could be wrong.
You'd be better off just getting one, instead of having it fix which will cost you more.
You should check the For Sale section. I believe there's a guy there that's parting out his Camaro. If not just go to the junk yard.
I had a aftermarket with fans but went back with a stock style radiator and fans, seemed to work better.
Its the biggest I found stock 1 1/4" core. The rest I think were 1" core.
Too long ago to remember, I know its one like ZZP was selling , It may be stock was 7/8 th thick and I got 1" thick. Don't know for sure. I found a oversized radiator from ZZP thats 1 1/4 I think thats the one, still not sure though.
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
