Hi All... just thought I would share this with the community.
I know that steel jack stands, properly used, are very safe. But I just always feel queezy getting underneath the car with them, especially when I need all four wheels off, and especially here in earthquake prone southern california. I like to be able to enjoy life when I work on my car, so I saw a version of these cribs on some other forums and decided to make my own. I also was going to do some suspension work, and need to have the suspension fully loaded while being able to get under there and tighten bolts.
While I was putting them together, I also had the thought to make four custom risers for putting under the subframes. They "lock" in place by slipping into the cradle where the wheel sits. You can shake the bejezzus out of the car, and the cribs dont even creak.
They are 16"x 21" by 10.5" tall, put together with exterior wood glood and 2.5" ext. screws. I drilled holes for all the screws so as not to split the wood. Total cost was around $75 and took about 6 hours to make.
My jack goes up to 19.5" inches and this is enough to get it up that high.
