Purge valve placement - FirebirdV6.com/CamaroV6.com Message Board
  • Purge valve placement
    I have a 01 firebird that I just swapped motors on now I have this purge valve that I cannot find where it goes or even how it goes I have looked for diagrams of my motor but no luck I also cannot find where the sensor plug is either just very frustrated
    Is the valve even needed ?????
    Can anyone please help I would be very greatfull
    Re: Purge valve placement
    Can you get a picture of it?
    1997 Chevrolet Camaro
    L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
      This is what I have
      Click image for larger version
Name:	phone pics 2012 661.jpg
        I believe that goes on the left (as you're looking at the engine) side of the upper intake and hooks up to the sensor of the back of the upper intake, and comes forward behind the alternator.
          I think there's a plastic line that hooks up to it as well on the other end. If you can't figure it out by the time I get off work ill look at my car for ya.
            Dont think I will as it is just problem after problem but the help is much appreciated THANK YOU
              Thats your Evap sensor , if you have Hptuners you can delete it out if you wanted.
                Ok u all may think Im an idoit but what are HPTUNERS
                I swaped motors from an 97 camero to my 01 firebird would that make a difference
                with this
                  with this
                  hptuners is something you plug into your obd port to change the factory settings on your cars computer, to simply put it.
                  it doesnt matter what engine is in the car, just what ecm you used, 97 or 01'
                    Is there anyway to bypass the purge valve and evaporative emission? I'm tired of getting the evaporative emission code and nothing I do fixes it. Thanks.
