i agree with Robert,
Dexcool is good stuff, i used it in several cars (and still use it with my Camaro) and had never any problems with it.
I refresh it every two years, with the 50% mix, destilled water.
Sure, i have read the problems with Dexcool, but mostly it was a maintenance problem, 5 a 6 years or 100.000 miles is too long.
"If your vehicle came with the inferior green stuff (propylene glycol), you must do a complete and thorough flush before switching to Dex-Cool.
Also make sure to stay away from 'organic based' rust inhibitor additives. They originated in Euro/Asian markets and are not compatible with Dex-Cool. These additives may cause gumming of the antifreeze. OEM style additives designed for use with the green antifreeze (propylene glycol) may reduce the durability of Dex-Cool.
If you started off with green, GM recommends switching to Dex-Cool in their technical service bulletins.
If you choose to continue using green, just check the alkalinity more often. Green will keep you protected thermally just as well as red."
