I have a friend that has a 96, V-6 that has a nasty habit of just doing nothing when you hit the key. Then out of no where it will start and run like it never had a problem. We have checked the neutral safety switch, changed the ignition switch and run new ground and batt. cables. I am beginning to think it has something to do with the security system. Anyone have any ideas???
No Start 96 Camaro
Re: No Start 96 Camaro
Is the security light on?1997 Chevrolet Camaro
Sounds like Vats.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Vehicle anti theft system.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Thanks, figured it out. Bad wire from key switch. intermittent connection of the OHMs resistance circuit of the key. When it was open you could tilt the wheel up and it would close and work. The only way I see around this is to put a resistor in line that has the identical Ohms resistance as the key to keep the circuit complete.
Thanks for the response. got us to thinking!!!
My vats went bad ended up buying a 00' steering column and bcm for $80 off ebay and installing it , works great.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
