I need help diagnosing... - FirebirdV6.com/CamaroV6.com Message Board
  • I need help diagnosing...
    Driving home tonight, I ran through third gear hard, and when I let out to coast back to speed limit,dropped it in nuetral and let it coast. Lights dimmed a bit, I look down no oil pressure, no rpm, it died. Completely. And did that repeatedly.
    My only thought was a fuel pump? But it starts up fine, no issue idling. No SES.. 2000 Camaro M5. I'm lost guys.
    Re: I need help diagnosing...
    Sounds like a MAF issue. Maybe pull it out and clean it a bit see if that helps?
    Team NoVa
      No issues today, did the exact same thing and it was fine...
        Run through any water or puddles?
        TEAM C6V6
          Negative..... dry as a bone
            Did it again today, and popped on a Service Vehicle light. Then wouldn't stay in 4th, and wasn't friendly with 3rd&5th... time for a clutch it seems.
              scan it
              Follow me!
              Or this
                Its not SES... It was service vehicle. The one inside the tach on the bottom left..
                  scan it anyways. not all codes turn the ses light on.
                  TEAM C6V6
                    just scan the damn thing, how you gonna ask for help then deny suggestions.
                      What does a service vehicle mean?... mine pops on when it gets really cold, but goes off if I restart it. I never denied, just don't know what it means.
                        Service Vehicle Soon Light
                        This light will come on if your vehicle has certain non-emission related problems.
                        For example, if the entire electrical system fails to send and receive messages from the vehicle's components, the SERVICE VEHICLE SOON warning light comes on.
                        These problems may not be obvious and may affect vehicle performance or durability. Consult a GM dealership for necessary repairs to maintain top vehicle performance. This light will come on briefly when the ignition is turned on to show that it is working properly.
                        Service Engine Soon Light
                        Your vehicle is equipped with a computer which monitors operation of the fuel, ignition, and emission control systems.
                        This system is called OBD II (On-Board Diagnostics-Second Generation) and is intended to assure that emissions are at acceptable levels for the life of the vehicle, helping to produce a cleaner environment. The SERVICE ENGINE SOON light comes on to indicate that there is a problem and service is required. Malfunctions often will be indicated by the system before any problem is apparent. This may prevent more serious damage to your vehicle. This system is also designed to assist your service technician in correctly diagnosing any malfunction.
                        Notice: If the vehicle is continually driven with this light on, the emission controls might not work as well, the vehicle fuel economy might not be as good, and the engine might not run as smoothly. This could lead to costly repairs that might not be covered by the vehicle warranty.
                        Notice: Modifications made to the engine, transaxle, exhaust, intake, or fuel system of your vehicle or the replacement of the original tires with other than those of the same Tire Performance Criteria (TPC) can affect your vehicle's emission controls and may cause this light to come on. Modifications to these systems could lead to costly repairs not covered by your warranty. This may also result in a failure to pass a required Emission Inspection/Maintenance test.
                        This light should come on, as a check to show you it is working, when the ignition is on and the engine is not running. If the light does not come on, have it repaired. This light will also come on during a malfunction in one of two ways:
                        Light Flashing -- A misfire condition has been detected. A misfire increases vehicle emissions and may damage the emission control system on your vehicle. Diagnosis and service may be required.
                        Light On Steady -- An emission control system malfunction has been detected on your vehicle. Diagnosis and service may be required.
                        If the Light Is Flashing
                        The following may prevent more serious damage to your vehicle:
                        Reducing vehicle speed
                        Avoiding hard accelerations
                        Avoiding steep uphill grades
                        If you are towing a trailer, reduce the amount of cargo being hauled as soon as it is possible
                        If the light stops flashing and remains on steady, see "If the Light Is On Steady" following.
                        If the light continues to flash, when it is safe to do so, stop the vehicle. Find a safe place to park your vehicle. Turn the key off, wait at least 10 seconds and restart the engine. If the light remains on steady, see "If the Light Is On Steady" following. If the light is still flashing, follow the previous steps and see your GM dealer for service as soon as possible.
                        You may be able to correct the emission system malfunction by considering the following:
                        Did you recently put fuel into your vehicle?
                        If so, reinstall the fuel cap, making sure to fully install the cap. See Filling the Tank . The diagnostic system can determine if the fuel cap has been left off or improperly installed. A loose or missing fuel cap will allow fuel to evaporate into the atmosphere. A few driving trips with the cap properly installed should turn the light off.
                        Did you just drive through a deep puddle of water?
                        If so, your electrical system may be wet. The condition will usually be corrected when the electrical system dries out. A few driving trips should turn the light off.
                        Have you recently changed brands of fuel?
                        If so, be sure to fuel your vehicle with quality fuel. See Gasoline Octane . Poor fuel quality will cause your engine not to run as efficiently as designed. You may notice this as stalling after start-up, stalling when you put the vehicle into gear, misfiring, hesitation on acceleration, or stumbling on acceleration. (These conditions may go away once the engine is warmed up.) This will be detected by the system and cause the light to turn on.
                        If you experience one or more of these conditions, change the fuel brand you use. It will require at least one full tank of the proper fuel to turn the light off.
                        If none of the above steps have made the light turn off, your GM dealer can check the vehicle. Your GM dealer has the proper test equipment and diagnostic tools to fix any mechanical or electrical problems that may have developed.
                        Emissions Inspection and Maintenance Programs
                        Some state/provincial and local governments have or may begin programs to inspect the emission control equipment on your vehicle. Failure to pass this inspection could prevent you from getting a vehicle registration.
                        Here are some things you need to know in order to help your vehicle pass an inspection:
                        Your vehicle will not pass this inspection if the SERVICE ENGINE SOON light is on or not working properly.
                        Your vehicle will not pass this inspection if the OBD (on-board diagnostic) system determines that critical emission control systems have not been completely diagnosed by the system. The vehicle would be considered not ready for inspection. This can happen if you have recently replaced your battery or if your battery has run down. The diagnostic system is designed to evaluate critical emission control systems during normal driving. This may take several days of routine driving. If you have done this and your vehicle still does not pass the inspection for lack of OBD system readiness, your GM dealer can prepare the vehicle for inspection.
                          So what about cold would make that pop on?
                          No codes on 3 different scanners.
                            My ultimate guess is something unrelated to that light is causing your car to stall out during 3rd / 5th gear (bad clutch?) and when it stalls your car loses electrical power and the sudden loss of power is causing the PCM to believe you have an electrical failure as your car died while the ignition was on and there were no reported misfires - ect... and triggers that light as its a vehicular problem but not emissions related... but unless you have a bad ground, I don't think it's the cause of your problem.
                              I know my fuel pump has had better days. Would that cause it?
