Lightening The Car. - FirebirdV6.com/CamaroV6.com Message Board
Lightening The Car.
  • Lightening The Car.
    In an attempt to lighten the car a little, I wanted to remove some of the heat shields. Is it a bad idea? Are they all necessary or can some be taken off?
    Thanks.
    Re: Lightening The Car.
    I would leave the heat shields alone. They keep things from melting.
    Things you can remove:
    Front bumper support
    A/C system
    Keep washer fluid at 1/4-1/2 full.
    Rear Seats
    Carpet
    Sound deadening material under carpet
    Floor Mats
    Door Panels
    Rear Seatbelts
    Stereo/Amp/Speakers
    Spare/Jack
    The rest of the interior plastic
    Things to replace with lighter stuff:
    Tubular K-Member
    Tubular Upper & lower a arms
    Aluminum Driveshaft
    Dump exhaust before axle
    Distribution:
    Move battery to trunk or run smaller battery.
    Here is a link of weights of different parts -http://www.bfranker.badz28.com/fbody/weights.htm
    96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
      Tony, mine are all gone with the exception of the one above the cat (stripped bolt I can't get out with my exhaust in the way) and the one by my gas tank.
        I'm going to attempt to install my headers and sub-frame connectors soon, and I thought while I was under there, I might as well get rid of some stuff:)
          Hahaa, now you're taking after my motto...should add a few of my suspension parts while you're down there ;)
            What have you got Mike?
