oil problem - FirebirdV6.com/CamaroV6.com Message Board
oil problem
  • oil problem
    i have a 96 3.8 camaro and i thought my oil pump was goin out but the mechanic said i have a clog in the oil system. whats the easiest way/cheapest way to fix it???
    Re: oil problem
    well wheres the clog? replacing the pump is pretty easy, it's right behind/attached to the front cover...
      Re: oil problem
      I had the same problem need to drop oil pan, clean oil pan because you will have oil build up. No need to change oil pump just clean .
      Camaro V6 1999- K&N Intake System
      - 3.73 gear
      - Jet DST Programer
      - Spark plugs (Split Fire) and wires (Taylor 8.5)
      - Headers (Pace) and Y- Pipe
      - Hi Flow Cat
      :stp:
        Re: oil problem
        there are solvent solutions. some people don't like them, some people praise them... i would give one a try, you can use seafoam, rosloan? marvel mystery oil etc. but pulling valvecover and oil pan are the best way.
          Re: oil problem
          Mmmm oil sludge!
          Time to pull the covers and clean her out! Probably have it built up on the oil pickup tube screen too.
            Re: oil problem
            Try Rislone...I did on my 3.8 and oil pressure is higher longer and little
            fluxuation as before.
