Rad Fans. - FirebirdV6.com/CamaroV6.com Message Board
Rad Fans.
  • Rad Fans.
    Are the rad fans wired to turn on at the same time or will one turn on, then the other if needed. I heard the fans running for 5-10 minutes after I shut the car off. When I opened the hood, only one was running. I'm guessing it has to run longer to do the same job as 2 fans.
    Re: Rad Fans.
    They turn on seperate , low turns on 1 then high turns on the 2nd one.
    • Andy H
      Transmission removal help!!
      by Andy H
    • 2.8 Bird
      Abs inop
      by 2.8 Bird
    • fishin
      by fishin
