Hello everyone,
I'll be under the car for a couple of weekends and thought to maybe drop the fuel tank and put in a new fuel pump while I was re-doing the exhaust and installing sub-frame connectors. I was wondering if the later model plastic fuel tanks would fit my 96 Camaro. Are there any modifications required to make it fit?
What year did they introduce the plastic tank? I have a small leak to find and if its not the evap cannister or a hose I may need a tank and the no rust option sounds much better to me.
96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
