okay my ac has never worked since i had this car i can charge it up and it will work for a few days then slowly leak out where would a good spot be to look for the leak and could i use the spray bottle with soap in it to look for the leak like you can do to tires
ac leak question
Re: ac leak question
What year you working with?? I had an issue and found the to the pipe that runs from the drier to condenser. It had a leak under the rubber cover. I have an 01 camaro with 3.8. The way I found it, was I used the dye and saw it come out from rubber. I boughs. The new pipe from rockauto and fix the problem.
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...13 hours ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 days ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...6 days ago
