My sister has an 05 altima and I've had trouble finding a frequented forum that has knowledgeable people visiting. There is a pulsating noise that increases in frequency and seems directly proportional to road speed coming from the right front wheel. No change if I shift into neutral. Loudest turning left, almost gone when turning right though still pretty loud if you're going straigh, speeding up or slowing down. The brakes were pulsating when applied so I put new front rotors on earlier today. That got rid of the pulsating brakes (rotors were visibly warped - apparently Monroe uses crappy rotors. The pads after almost 2 years were still great). Also swapped the front wheels when I was doing the brakes to rule out a bent wheel. Is there anything left to eliminate besides the bearing and or hub assembly? Sway bar and tie rod ends all looked intact.
05 altima - wheel noise
Re: 05 altima - wheel noise
It sounds like someone put a piece of plastic that is hitting against a couple bumps on the wheel - Its definitely more of a clicking or popping than a grinding noise.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Shop replaced the front left bearing - noise gone(I could have sworn it was the right making the noise).96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
