Crankshaft sensor bad. Balancer wobbly and worn. Replacement part doesn't exist any longer--even GM says they're obsolete? WTH? Where in the hell can I find a replacement for a 2000 Camaro 3.8 V6? Son of buck. There is NOTHING in a Google search.
No harmonic balancer anywhere in the US? Help!
Re: No harmonic balancer anywhere in the US? Help!
gmpartsdirect.com
12563281 - BALANCER
GM PART # 12563281
CATEGORY: Eng Asm (shipped only to local UPS hub 4 pickup)
PACK QTY: 1
CORE CHARGE: $0.00
List Price: $306.89
Price: $178.50
You Save: $128.39 (42%)
DESCRIPTION: BALANCER
Who are you talking to?
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
From www.rockauto.com
Dorman part #594004 $63.79
ATP part #102074 $72.99
ACDelco part #12563267 $149.79
That was easy. Don't always rely on specifically GM to supply parts. Many aftermarket companies make OEM parts, and will for a long time.1995 Pontiac Firebird
Thanks for the input and help. I went on Ebay and found a Dorman for $76.26 including shipping. I bought it from thepartsstore. I'll have it by Monday which is great!
@FirebirdGT--I got the info on no available parts from the garage I took the car to; he replaced the sensor and I'm taking the car back next week after the balancer comes in. I'm guessing (don't know for sure) that garages only want to deal with actual part stores or dealerships. Luckily, he's cool with my getting the part and slapping it on for me. A lot of places in my neck of the woods won't do that for a customer these days.Groovy is as groovy does.
Because there are liabilities involved with bringing your own parts to install, especially at chain shops. That and most shops like to add 10 or 20% of the part they install on markup.1995 Pontiac Firebird
Originally posted by bigbrian442 View Postmake sure they do a case learn after replacing the balancer.
Raven
Yes, the relearn was done after the sensor replacement.
I'm wondering what else I need besides the balancer and the bolt? Do I need a sleeve and some lube too? I don't want the repair delayed because of my ignorance. As it stands, the shop is individually owned and he's not charging me a fee aside from the labor, so I'd prefer to bring him everything he needs to avoid additional charges.
He did say there wasn't anything wrong with the bolt, but I read in these forums that you should just replace it when you're installing a new balancer. It's a $7 part, so either way it's no big deal.
Almost had a heart attack! Search on Amazon said the Dorman 594-004 didn't fit on my 2000 V6 Camaro. Ebay says it does. Good gawd. I hope I'm not getting the wrong part? MoGobs 30th has the same information I do. I was about to blow a gasket!
I wish I knew more about cars. I hate being a total novice.Groovy is as groovy does.
GM changed the design of the balancer for 1997 model engine. The 97+ balancer is better - if GM part.
I have the newer GM balancer on my 96.
Raven
Originally posted by FirebirdGT View PostGM changed the design of the balancer for 1997 model engine. The 97+ balancer is better - if GM part.
Originally posted by Mogobs30th View PostTrue, but that's the balancer itself. I didn't think there was a design change to the crank itself that would prevent one model year balancer to not work on another model year. Technically, a 95 balancer will work on an 02, correct?
Raven
