Short belt- electric wp and ac delete - FirebirdV6.com/CamaroV6.com Message Board
  • Short belt- electric wp and ac delete
    I know ive seen this post before, but cant find it.
    Just got the electric wp and already have ac delete.
    Re: Short belt- electric wp and ac delete
    I'll post a picture of my setup later...your looking for how to route it?
      ^^^^ What he said.... Ifyou need belt length i may still have the one that I used when i did the same. As far as belt routing it will go crank straight to the alternator and then to the power steering and back to the crank. The tensioner will put pressure on the smooth side of the belt pushing it twords the driver side of the car. The one question i have is you say you have an AC delete, i assume you mean a pully is now in the AC's place. You wont need that for the way i did mine.
      Daily: '02 Black Yukon Denali
      Toy: '06 Torrid Red GTO
      Gone: '07 Charcoal Yamaha R6
      Gone: Ex-wife, lol
        if you are just looking for a length, just take a piece of string, route it. Then measure the string, add like an extra inch so the tensioner can do its thing and take that number to autozone or wherever.
          I deleted the ac its no longer there. Would like belt #.and how its routed
            Belt number I totally forget, but I can show you how it is routed, I'll snap a quick pic when I go back out in a bit
              Ok but if anyone could grt me belt # it be much appreciated
                Anyone? I know ive seen a post on this before. Believe it was oneeightseven ad kristen n commenting on belt number
                  My belt is 60" with my ac delete, but I don't have the electric water pump. Have you tried measuring for one?
                    I have not bought electric wb yet... Gauging ad gathering inf. It comes with 4in shorter belt bit my ac compressor is completley gone.
                      Here ya go.
                        I have muly idler bracket in, just with grooved pulley now
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
