Replacing Gaskets Checklist - FirebirdV6.com/CamaroV6.com Message Board
  • Replacing Gaskets Checklist
    As some as you may know I need to replace my upper intake for sure. Im going to do the bottom one as well as long with elbows. Heres everything I have so far:
    Fix upper and lower intake gaskets
    http://www.autozone.com/autozone/par...6_482003_5297_
    http://www.autozone.com/autozone/par...er=148754_0_0_
    Cooling Elbows
    http://www.autozone.com/autozone/par...7_155956_2826_
    Would these elbows be better?
    http://shop.zzperformance.com/store/...nt-Elbows.aspx
    Would I need a water pump gasket?
    http://www.autozone.com/autozone/par...147723_0_5537_
    Valve cover gaskets since im taking them off and cleaning/ painting them:
    http://www.autozone.com/autozone/par...7183_167769_0_
    Also what is the length of our serp belt?
    Im getting a new one as well since my old one is starting to crack
    http://www.autozone.com/autozone/acc...mString=search
    Any other gaskets I would need?
    Re: Replacing Gaskets Checklist
    UPDATED
    Found some of the same stuff even cheaper on rock auto :headbang:
    Fix upper intake gasket
    Rock auto-FEL-PROPart # MS98014T $49.79
    Lower intake gasket $13.99
    http://www.autozone.com/autozone/parts/Victor-Reinz-Intake-Plenum-Gasket/2001-Chevrolet-Camaro/_/N-jf8rhZ93yj2?itemIdentifier=148754_0_0_
    CoolingElbows $14.99
    http://shop.zzperformance.com/store/p/1127-Aluminum-Coolant-Elbows.aspx
    ValveCovers gaskets $9.78
    Rock Auto - FEL-PRO Part # VS50080R
    Water pump gasket $3.63
    Rock Auto -VICTOR REINZ Part # K30793
    O-Rings $8.99
    http://www.autozone.com/autozone/accessories/Help-30-pcs-Assortment-Fuel-Injector-O-Ring/_/N-25hc?itemIdentifier=347152_0_0_
    Belt: $13.82
    Rock auto - GOODYEARPart # 4060945
      upper intake should be the cheaper one and elbows at advance auto parts are only $4.19. Elbow is the first place I look when I get a coolant leak. :tup:
        I have puddles of antifreeze inbetween my fuel injectors
          I'd replace the thermostat while you've got it apart. The o-rings that sandwich between the upper and lower plenum usually come with the intake gaskets.
            Fix upper intake gasket $49.79
            CoolingElbows 13.95
            http://www.ebay.com/itm/Dorman-Help-...599#vi-content
            O-Rings $8.99
            Belt: $13.82
            Thermostat $3.26
            STANT Part # 13848 {#35848} OE Type Thermostat; 180 Degree Reverse Poppet (1 23/32" x 13/16" x 25/32")
              Should I also think about doing the fuel pressure regulator?
                Glad to see your checklist is building and of great help for all to see.
                Fix the gaskets and if the FPR isnt giving you problems I'd leave it alone for now unless youre the type to have the entire top end covered.
                Money well spent from Murphy's Law...
                " If there is a choice between several parts going bad, the one that goes bad will be the most expensive and hardest to get to "
                :D
                Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
                  I was just thinking might as well do it since everything is going to come off
                    Its good to replace it if you have the chance and you have alot of miles on your car.
                      I don't mean to hyjack but does the egr valve have some kind of gasket?
                        I think so but Im prob going to do a egr delete since Im also planning on doing pacesetter headers and full exhaust. I have everything, Just need to install it lol
                        http://www.autozone.com/autozone/par.../N-jf8rhZalize
                          Mine had no gasket and none those would fit anyway not the right shape.
                            Says they would work lol, is my egr different then yours?
                              Far as I know there all the same, they all mount in the same spot, headers and intake no matter what year on the 95-02 3800 fbodys.
