I'm interested in Hypertech's Maxenergy programmer but its only available for 2000 and up camaros with the 3800V6 and mine is a 97 camaro with the 3800. I would like to know the difference between the two engines and if I can make mine the same so I can tune it with the power programmer.
difference between a 97 camaro 3800 and the 2000-02 camaro 3800?
Re: difference between a 97 camaro 3800 and the 2000-02 camaro 3800?
Might as well get hptuners for your car, it won't pay off trying to get yours 00' and up. You'll have to sell yours and get a 00' and up most likely.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostMight as well get hptuners for your car, it won't pay off trying to get yours 00' and up. You'll have to sell yours and get a 00' and up most likely.
The intakes ,TB, wiring and pcm. too much to do for a programmer. Might as well get the real deal and go Hptuners.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Camaroteen View Postwhats the difference between the intakes?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Thanks I get confused on the 98' cars.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
HPTuners is compatible with 97& up so I'd go that route.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
96's work with a 97' PCM also.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
