pipe above waterpump leaking - FirebirdV6.com/CamaroV6.com Message Board
  • pipe above waterpump leaking
    New to the forum although I use the information all the time. My son has a 3.4 v6 and the pipe that has a quick disconnect above the water pump that goes in the lower intake manifold is leaking. not at the threads but at the quick disconnect part. any sugestions how to get this to stop. the threaded part that threads into the manifold is new.-thanks
    Re: pipe above waterpump leaking
    Don't mess with the cooling system...these cars have a habit of overheating and throwing a rod then its time for a new engine....it happened to me AFTER..I replaced
    all hoses, radiator, intake gasket...it was determined to throw a rod and it did.
      Can you snap a pic of where its leaking?
        Lancer, post a pic if you can. It might just need to have the hose replaced.
        You also tossed bars leak into it. The rods aren't directly connected to the cooling system, only thing I can think that caused that is you overheated it again, popped a headgasket and hydrolocked your motor, thus causing you to chunk a rod.
          i'll that but my son has it at work thanks guys
            oh and by the way i cant afford the time or the money to throw a rod
              Could you Seriously beat a dead horse anymore? You had some bad luck, don't give out bad advice because of a bad experience.
              Daily: '02 Black Yukon Denali
              Toy: '06 Torrid Red GTO
              Gone: Powerdyned '02 Pewter Camaro
              Gone: '07 Charcoal Yamaha R6
              Gone: Ex-wife, lol
                It sounds like something wasn't tightened properly and it's causing a coolant leak. I don't know exactly where that leak is till we see the pic, but this could be nothing more than applying a proper torque spec with it. IDK.
