New to the forum although I use the information all the time. My son has a 3.4 v6 and the pipe that has a quick disconnect above the water pump that goes in the lower intake manifold is leaking. not at the threads but at the quick disconnect part. any sugestions how to get this to stop. the threaded part that threads into the manifold is new.-thanks
pipe above waterpump leaking
Re: pipe above waterpump leaking
Can you snap a pic of where its leaking?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Lancer, post a pic if you can. It might just need to have the hose replaced.
Originally posted by PalmHarbor View PostDon't mess with the cooling system...these cars have a habit of overheating and throwing a rod then its time for a new engine....it happened to me AFTER..I replaced
all hoses, radiator, intake gasket...it was determined to throw a rod and it did.
all hoses, radiator, intake gasket...it was determined to throw a rod and it did.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
It sounds like something wasn't tightened properly and it's causing a coolant leak. I don't know exactly where that leak is till we see the pic, but this could be nothing more than applying a proper torque spec with it. IDK.
