Fuel pump fuse location - FirebirdV6.com/CamaroV6.com Message Board
  • Fuel pump fuse location
    Hey guys, can somebody tell me where exactly the fuse for the fuel pump is on a 95 Camaro 3.4? I've got nothing marked fuel or fuel pump in the underhood panel or the one on the drivers side. I started the car the other day to move it so I could plow and the thing just stopped running and won't start again. I originally thought the battery or alternator but those checked fine. I don't hear the pump when turning the key so what to start with fuse/relay but can't find the damn things
    Re: Fuel pump fuse location
    I believe it comes off the "PCM IGN" fuse which is #5 in the I/P fuse block inside the cabin. So if the fuel pump or relay blows that fuse, the PCM is down also.
      That fuse is fine. Happen to know where the relay is? I googled but come up with several different locations. It's freezing cold and wet/snow right now so I can't head out yet.
        This site has a lot of useful information for your car
        http://shbox.com/1/fuel_pump_relay.jpg
          Thanks alot. Well I replaced the relay and still no dice. Next step, the pump:cry:
