Okay so I'm leaving school and I drive not even a mile and I notice my throttle is doing absolutely nothing. Push it to the floor and nothing. Slow down and try to go, it stalls. Stay in neutral or park and it idles really funky. So I pulled the codes with my tuner and got 9 of them. I'll post them shortly. But one was the same P0300 misfire I've been trying to fix. Changed all coils, wires, and plugs. So yeah no clue what's wrong.
reduced engine power, sloppy idle and stall
Re: reduced engine power, sloppy idle and stall
Could be that your throttle body is done. Is this a 99+ model year car?
Make sure your wires are all nice and tight and connections to the throttle body are good. Make sure you don't have any wires hanging under the car too, you might have a bad ground strap.
agreed with warshike also with the temp sensor looks like its getting way too much voltage according to the volts. check if you throttle body is getting power that may be the cause . out cars are mainly electrical so you need to diagnose if the part is just out or if there is a electrical problem
Something is wrong with the connection on the coolant temp sensor so it won't stay on. I can't tell if the throttle body is an issue or if the valvetrain finally went out. You floor the throttle and you get a little under 2k rpm. And like zero acceleration.
Originally posted by nwilson44 View PostSomething is wrong with the connection on the coolant temp sensor so it won't stay on. I can't tell if the throttle body is an issue or if the valvetrain finally went out. You floor the throttle and you get a little under 2k rpm. And like zero acceleration.
Originally posted by WarShrike View PostYou just cleaned it? As in you cleaned the engine bay? With what? Did you use a pressure washer or spray degreaser near the electrical connections or PCM?
Originally posted by thebeewantsboost View Postcould try running with the maf unplugged. its a shot in the dark but worth a try.
So diagnostics say that the Accelerator pedal was bad.... Is that normal? Anyone have that issue? $520 part at your local Chevrolet dealer.... SMH freakin stupid. Ill know tomorrow if that fixed it.
I think it would be something more than a pedal.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 days ago
