Okay so my car has the GU6 production code on it and I was pretty sure I had 3:42's prior to looking into it. 1st gear is kinda low for only a 4-speed transmission. Basically I did the LSD test when I was putting on my rear brakes today and I turned one wheel and the other wheel turned the opposite way. I thought that means you DON'T Have an LSD? My car had a rear sway bar and I know thats the right ratio but I am not sure why it didnt pass the LSD test. Any ideas?
3:42:1 GU6 Gears
Re: 3:42:1 GU6 Gears
Originally posted by nwilson44 View PostMy car is a 2001
But if you exit a turn hard then floor it, you'll feel the limited slip action.
Originally posted by Hib Halverson View PostIf the car is an 01 and you see Y87 in the list of RPOs, you have the Zexel Torsen limited slip diff. It will not react the way one expects using the "LSD test".
All of the RPO codes should be on the sticker on the edge of the drivers door, where I'm guessing you got the GU6 code from.
I took a picture of that sticker so I could look up what my car was equipped with from the factory. If you search a little on google you should be able to find a list of what all the different codes mean for your car.
Originally posted by BirdBrain View PostAll of the RPO codes should be on the sticker on the edge of the drivers door, where I'm guessing you got the GU6 code from.
