engine swap? - FirebirdV6.com/CamaroV6.com Message Board
engine swap?
  • #16
    Re: engine swap?
    well i decided to just buy a rebuilt 3.8. the guy told me though that anything i want done to the motor/put in/on is labor free as long as its done prior to the motor being put in soooo. my question is if you were in my shoes, what would you have done?
    money does matter so don't say turbo it or something crazy. i just wanted some ideas because i wasn't sure what he meant by ppl have things put in and such. only things he rattled off was a thermostat and aftermarket water pump
    • #17
      Re: engine swap?
      is most the items on zzperformance compatible with the camaro 3.8? i was thinking about getting
      http://shop.zzperformance.com/store/...ttle-Body.aspx
      is that the same TB as the camaro 3.8?
      http://shop.zzperformance.com/store/...dy-Spacer.aspx
      same for that?
      http://shop.zzperformance.com/store/...er-Intake.aspx
      http://shop.zzperformance.com/store/...ve-Pulley.aspx
      • #18
        Re: engine swap?
        Different TB's, I'd do cam, valve springs , pushrods , retainers and tune.
        • #19
          Re: engine swap?
          does the throttle body work with the camaro v6s that i posted in the link up there? theres also a throttle body spacer too
          • #20
            Re: engine swap?
            nope man i asked the same question a while back the responses i got were a no but the intake mainfold was on onother website
            • #21
              Re: engine swap?
              so the intake on that website doesnt work?
              • #22
                Id make sure allll the gaskets are replaced with good ones. Not cheap gaskets. 105# springs would be good. Also making sure the lifters aren't gunked up would be a smart idea. Would be hell of a lot easier to change all that now
                • #23
                  Re: engine swap?
                  You don't think they would do that with a rebuild?
                  I'd hope so for the amount of money I'm paying...
                  So this upper intake is good on the camaros right?
                  • 187shark
                    by 187shark
