How do I properly bleed my power steering? - FirebirdV6.com/CamaroV6.com Message Board
  • How do I properly bleed my power steering?
    Just changed my pump and I have no idea how to bleed it. I keep on turning it and reving it and it keeps making noise.
    Fill the reservoir and then turn the steering wheel from lock to lock several times.
      Re: How do I properly bleed my power steering?
      I did that and its still making noise? I did it with the car in the air and on the ground. No clue why its doing that.
        Don't know. Defective pump?
          My guess would be the pump also.
            So Take the pump back?
              Depends, what does it sound like? Is the same noise as when the old one went? IS the steering feel mushy? If its mushy you have air in it. If its just a noise the pump is probably bad. Did you check the belt tension?
                I just replaced the tensioner with an AC-Delco one and the belt should be tight. I have very light steering feel as of now and I have excessive noise.
                  On the LS1 you pull the belt and turn the pulley backwards a few times on the ps pump. Might be worth trying.
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
