So I have a 2001 3.8L camaro. The previous owner had the heater core bypassed come to find out. I'm assuming it was leaking. Is there a how to on how to change it?
Heater Core How to?
Re: Heater Core How to?
Originally posted by nascar24jd View PostYou should hook it back up first to determine if it is in fact leaking.
Long story short, It looked like they had a leak and didnt know where it was coming from. Then found that it was coming from the heater core. I later validated this while looking through my receipts (mostly my receipts but the few that the last owner had), I found a diagram of the cooling system.
Put all this information together and I am pretty sure it was leaking. I just want to replace it.
I just want to see what I am getting myself into first.
you have this gunk in your intake after your rebuild?
Originally posted by LETZRIDE View Postyou have this gunk in your intake after your rebuild?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by FIREBIRDV6RAGE View Postnever ever use that stop leak stuff it just clogs the cooling system just saying, anyways i believe you have to remove your entire dash and then you will see it and just replace it thats all.
I would have to add more every ~6 months or so because the leak would come back
Originally posted by cam98aro View Postiv used that stuff before on my beater car, and it never clogged.
i wouldn't recommend it if you want to take the risk and fix it on the cheap. hey go ahead .
I've used the stuff to fix my head gasket leak, fixed it right up.( stuff used carbon fiber for $60) Its been over a year no problems. This was after I used MLS head gaskets with copper spray. I didn't feel like taking the head off again so thats what I used, normally I would fix the problem though.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...27 minutes ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 days ago
