Hello I have a 2000 camaro. About a month ago I got a remote start installed buy best buy they did a great job. And for about 2 weeks now my security turns on and starts to blink even if i try to remote start. I bought a new key didn't solve the problem and also some times it would fix it self by turning the blinking security light into a solid light and could start with key and remote. I took it to best buy yesterday they checked the remote start for about 3 hours and it wasn't the problem. They said they have never seen something like this . So I was thinking about just by passing the vats system by using the resistors that add up to my key. Is the wiring still set up where I can find the two wires that I can put the resistors into. Or is it messed up by the remote start? And another question instead of using resistors could I just take a old key that still works cut out the resistor without damage and solder two wires to the points and put the two wires were the resistors were goin to go?
Camaro security light Vats system problem help!!!
Re: Camaro security light Vats system problem help!!!
yes, you can cut the key instead of using a resistor, and it should work.
my guess is when they were installing the remote start they were rough on the key/ignition and the small wires inside broke. when you program it you have to turn the ignition on and off several times and fast.
