Got a pic of the crate motor. Looks good as of now, should be in the car ready tomorrow.
Engine Pic
Re: Engine Pic
There is a picture of my before and after rear sway bar picture. which by the way I had a question about, but I will get to that. then there is one of what it looked like before the last tear down.
As far as the rear sway bar, I dont think I installed it right? It crashes occasionally and its that. The original problem was that the after market bracket that bolted to the car kept coming loose making for a lot of noise. So I put back the stock ones held on with 2 bolts instead of the 1 on the aftermarket set up. Now it makes almost no noise but I am not sure how tight to tighten the horseshoe bolts on the axle. any suggestions?
Re: Engine Pic
Since it's a factory crate motor, could it be a series 3 L26 instead of the older series 2 L36? I would assume since they are the same engine that they would all be the newer model. I have no clue, I'm just thinking out loud here...aka FreedStyle
Chaddrich Freed
(1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
2008 Silverado Crew Cab 5.3L 4x4
Re: Engine Pic
Originally posted by CFreed11 View PostSince it's a factory crate motor, could it be a series 3 L26 instead of the older series 2 L36? I would assume since they are the same engine that they would all be the newer model. I have no clue, I'm just thinking out loud here...
Re: Engine Pic
No, the difference is not visible to the eye, from outside the motor anyway. The newer L26 would have powdered metal rods instead of the casted rods ours originally came with. I forget if there is a slight difference in valve size or not. Regardless, it would bolt right up and fit in our cars just like the original motor.aka FreedStyle
Chaddrich Freed
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...20 hours ago
