500 hp dd??? - FirebirdV6.com/CamaroV6.com Message Board
500 hp dd???
  • 500 hp dd???
    so i was thinking about what my goal is for my camaro,and what i would like to do is make 500 hp and be able to dd it.But i got a few questions.
    supercharge or turbo
    would a l26 long block be good for dd 500 whp
    stick with my 10 bolt or upgrade(for trans i going to do the t56 swap)
    and would i still be able to pass all the nc car inspection stuff when they hook up to your computer and use your obd system
    Re: 500 hp dd???
    LSx..
    aka FreedStyle
    Chaddrich Freed
    (1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
    2008 Silverado Crew Cab 5.3L 4x4
      Re: 500 hp dd???
      but with a lsx how can i keep it where i can get an inspection and all
        Re: 500 hp dd???
        and i have been looking around ls1 tech for a good deal
          Re: 500 hp dd???
          - Turbo
          - 8.8/9/12 bolt rear end
          - A4
          and depends how you modify the car. You can tune readiness sensors to be in a constant ready state like this http://highperformancejunkies.com/tu...sensor-tuning/
          You may only need to worry about visual inspection, but depends on what you do to the car. You don't need to bypass any emissions stuff really.
            Re: 500 hp dd???
            A 500 HP daily driver will not come from a V6.
            LS1... Buy a car with one in it.
            In America's Hat!
            1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
            2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
              Re: 500 hp dd???
              so a daily driven 500hp v6 would be possible but id lose my a$$ with the money id have to put in it vs if i got an ls1 and made 500 hp out of it ?
                Re: 500 hp dd???
                i figured there was a way to do this:bowdown: ,and yes its mostly hook up to the computer and if it says the senors are all in the ok it passes
                  Re: 500 hp dd???
                  head/cam/intake on an LSx will get you 500hp at the wheels.. To do that kind of power with a v6, I would think it wouldn't be very street friendly, not to mention you'd be getting real close to a breaking point with a lot of parts. A rear end and transmission is a must at that point.
                  To do an LSx swap, or just buy an LS car, would be the cheapest, easiest way to go. H/C/I swap on an LSx and you can have 500hp and reliability...
                  aka FreedStyle
                  Chaddrich Freed
                    Re: 500 hp dd???
                    Must be nice... HCI LS1 is good for ~380 here..
                      Re: 500 hp dd???
                      rear end and tranny is a weak point even if you are LSx. The A4 is virtually the same thing we have just with bigger input/output shafts...that doesn't make the tranny stronger. 10 bolt is the same crap we have just you get a posi that you can chew up and spit out instead of an open diff. I killed 2 of them cam only with a stall and slicks.
                      tranny and rear end is money you are going to have to spend regardless. After that point you can either spend the money to motor swap and then go heads/cam/intake, or spend the money on a quality turbo kit and go head/cam with the v6. At the end of the day, you'll probably spend the same amount of money give or take a few bucks
                        Re: 500 hp dd???
                        I corrected that..."LSx", My buddy has an LQ9 H/C/I that layed down 470. I don't know the specs on his setup tho. All I know is LQ9 block/rotating assembly, and worked over LS3 heads and intake.
                        aka FreedStyle
                        Chaddrich Freed
                          Re: 500 hp dd???
                          So what's the rearend I would need,I know I won't a T56 trans.
                            Re: 500 hp dd???
                            9" or 12 bolt.
                              Re: 500 hp dd???
                              500 on a good turboed V6 is possible. There are a ton of 86-87 Buick GN's that do it. If you have ever looked at the engine structure of a series II it is way better than a old 109 block GN motor. A stock NA 3800 makes ~200. A cam and heads would get you to ~240. Thats like 20PSI to 500.
                              You are going to need a good sized cam, valvesprings, ported heads, ect. 500 out of a 3800 is like 800ish out of an LS1 so its going to have to be a decently thought out build but its more than possible. GN's need a girdle on the mains around the 10 second mark. You wont need that with a S2 3800.
                              Just cant be a wimp and run around on 11 PSI like it seems most turbo people do. As long as you run a decent intercooler, 93 and alky or E85 you should be able to get 25ish PSI.
                              LS is an easy 500, but getting everything for the LS swap isnt. With all the LS swaps going on now used F body oil pans, intakes, accessory drives, and harnesses are like gold. Around here you can get a 12 sec Z28 for 6-7 grand. Its going to cost no less than 3 to do a proper, good looking LS swap. If you cheap out, 2, but you cant run a truck intake or accessories in an F body.
