the fitting is going to coorelate with the drill bit and tap you use. i don't even know what size this hole is but when it comes to npt fitting. 1/4", 3/8" and 1/2" are the most popular. the filter is soft aluminum and super easy to tap.
In the process of doing this now. I drilled out the bypass. Wad super easy. And you have to be a complete idiot to mess it up. Its pretty safe to drill into. Once you get all the metal out that holds the bypass valve in you will see how its a bit hard to mess things up. I havent taped it yet or got the npt fittings yet but thats next. I did find this which was very http://www.fullthrottlev6.com/forums...rd-Build/page3
