Some questions - FirebirdV6.com/CamaroV6.com Message Board
Some questions
  • Some questions
    So I am getting closer to the Pacesetter header install, and I need to know if I can run the MSD 8.5mm Super conductor wires or not? The boot is straight but I can get the heat wrap around them? Not sure what will work, without running into the problem.
    Secondly, The cat. If I do a cutout should it be before or after the cat? I dont want any issues with the cat again so I need to get one that wont give me any issues.
    I know my car says GU6, meaning I have a 3.42:1 gear. I am still confused if that means I have a posi or not. Every time i gun it around a corner I come back to find only 1 275 section width black line and not 2... I assume I dont have a posi, because it also failed the jack the car up and spin the wheel test.
    Lastly, a tune. I am running a hypertech now but not sure if that will be good after the install.
    Re: Some questions
    Look for G80 next to GU6 which is the rpo code for the posi rear end.
    <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
      Re: Some questions
      Alrighty. what about the ignition wire boots?
        Re: Some questions
        90 deg boots MSD 8.5MM Super Conductor Ignition Wires #32799
          Re: Some questions
          I use straight boot 10.2mm wires with boot protectors no problems.
            Re: Some questions
            So boot protectors should alleviate any issue that should arise?
